Using step2 to control maxpos slave
  • I make a simple explanation about the control scence:
    The control signal comes from a joint (0 to 360°) of the Control hand, The Control PC will collecting the joint angle,and  sending  the  control commands to step2.
    The STEP2 part has been automatically generated using the NRMKEtherCAT Configuration Tool.
    MAXPOS servo drives provide complete DC functions, and It enables synchronized communication across slaves based on one reference clock. The cycle period is setting to 1ms. So The communication cycle between the controller and the driver is 1ms. And The drive position loop cycle is 1ms. It’s right?
     I will send a new position from control PC each 1ms. Do I need to do interpolation processing?
    Can you some advice to improving:
    1.How to avoid the frustration of the motor, the rotation is not smooth, and the discontinuity.
    2.How to achieve high real-time operation?
    Thanks!
  • Different steps are floated for the control of the new mode for the technology. Rate of the cv people reviews is extended for the changes. Mode is inflicted for the mode for all issues for the changes for the partial means for all shows.
  • All new and Informative post you share with us. I'm Abul Majid sheikh HR executive of Best Resume Writing Services in UAE  Tian I appreciate you for your experiment and for sharing it publicly. great work.
