Step 2 PC Problem
  • Hello ~ I am from Shinshinsa. We are trying to use the step 2 to control the panasonic motor by ethercat. I installed the PlatformSDK, Windows, V3.0.5 for Step 2. Now I have some problems.
    1. my NRMK Launcher does not have the Ethercat Tool.
    2 When I used the Eclipse to build the example in the Neuromeka folder in C Folder. I got this error.
    Please help me to solve these problem
    Thank you so much.
  • Hi Mr. Quang,
    Here are my answers for your questions.
    1. Please find the EtherCAT Tool at this URL (http://works.do/xuka73).
    2. At first, please follow our instructions here (http://docs.neuromeka.com/2.3.0/en/STEP/section2b/)
    If you still have problem, please let me know.
    Thanks.
    Thach
  • @thach-do
    Hi Mr.Thach.
    Many thanks for your help.
    1. For Ethercat Tool, I installed it, now it integrated in NRMK laucher.
    2. For Eclipse Debug, I still got problem.
    the problem is CMake Error (when I make Release and Debug folder). You can see
    "CMake Error at /cygdrive/c/Program Files (x86)/neuromeka/NRMKPlatformPC2/Drivers/cygwin_cmake/share/cmake-3.13.2/Modules/CMakeTestCCompiler.cmake:52 (message):
      The C compiler
        "C:/Program Files (x86)/neuromeka/NRMKPlatformPC2/Drivers/i686-unknown-linux-gnu/bin/i686-unknown-linux-gnu-gcc.exe"
      is not able to compile a simple test program "
  • Hi Mr. Quang,
    Could you please zip your project and send it to my email at thach.do@neuromeka.com?
    Then, I will check the project setting and fix it for you.
    Thach
